MX - BGP updates from 'weird' RID
RaphaelL
Hi ,
We are running BGP on our spoke/hub.
When looking at the route table the nexthop ( which is the HUB ) is identified with a weird RID ( always starting by 6.X.X.X )
When taking a packet capture you can clearly see the HUB sourcing these packets :
PS : Both screenshots were taken on different hub/spoke , the 6.X.X.X is not a match.
Why ?
This is super confusing.
5 Replies 5
Strange, have you asked Meraki support?
RaphaelL
Yes. I was curious if anyone has experienced that or has any idea about it.
Happens on any version ( 15.44 , 16.16 , 16.16.16 , 17.10.2 and so on )
As far as i can tell meraki uses 6.0.0.0/8 for things like management tunnel and maybe autovpn tunnel id. But also ibgp.
It would be better to use or add the hub name in the gui
I have also seen syslog(from one armed concentrator) coming from this address through autovpn.
Did also read about a mv using this address range so i guess every meraki device has one
RaphaelL
Kinda weird since they don't own 6.0.0.0/8. I know it's only used for services that you described but still
@ww is right.  You also see this address range used when an AutoVPN spoke does not have it's LAN subnet included in the VPN and accesses another site's LAN (which is included in AutoVPN).  The traffic from the source site gets NAted into the 6.x.x.x range (ps. you can use this trick to support spokes using the same LAN subnet range).
