We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Is there an API to allow configuration of the Active Directory authentication? I can't seem to find one in any documentation.
In the dashboard its Security & SD-WAN > Active Directory
Solved! Go to solution.
Feedback from support case:
Unfortunately, the ability to do this is not an available feature on the Meraki product suite currently.
As far as I (also) can see, there's not an API endpoint for that one.
