MS120-8LP showing offline on dashboard
Hi all,
Just got my kit through after completing the CMNA, and have encountered an issue.
I've connected it all up and it is all working for both wired and wireless, problem is that, even though its all working, the switch (MS120-8LP) is still showing as offline on the dashboard.
I've went on http://switch.meraki.com/#connection and its up and healthy on there and says its connected to the cloud!
Any ideas?
EDIT: Literally as soon as I posted this, it sorted itself out... Thanks for the magic fix, meraki!
2 REPLIES 2
Re: MS120-8LP showing offline on dashboard
@Cozzycam  If you are setting up a brand new device sometimes it can take a while for the device to appear connected in the cloud as there are a few steps the device has to complete i.e. firmware sync and config sync.
The first time you plug them up they change their firmware to the one configured for youtr network.  I've had them take many hours to show as online.
