Good day, I have a query if this setup is possible in Meraki MX high Availability. We already use the MPLS Lan connection for primary WAN in MX, but we noticed if the primary MX was fail the MPLS will not takeover as primary WAN because it has no physical connection to secondary MX. Instead its automatically failover to SDWAN uplink. Is it possible to connect the 1 MPLS circuit in both primary and secondary MX to have failover in MPLS WAN link. Please see diagram for further information.
We tried to add a switch in between but we encounter loop in these setup
Thank you in advance
