MDT and Cisco Meraki MX
SamuelM
We have MDT (Microsoft Deployment Toolkit) server on the LAN for Windows deployment. We enabled DHCP rogue alert and when we deployed computers an alert is rised.
I tried some Boot options : several Boot next-server and Boot filename. Nothing work.
Anyone else have this issue ?
Thanks.
On Meraki switches, you can mark a DHCP server as "authorised", but you can't do this on the MX.  It assumes if it is configured to be the DHCP server there should be no others (normally very valid).
I don't think you have any option but to turn this alert off.
SamuelM
Yes, sure. However, there is a option on Meraki MX on the DHCP : Boot Options, Where we can specified a Boot server and a boot file name. But I never found the good entries (for not rise alert)...
Regards.
Tedster
Also driving me nuts , did you ever get a solution for this?
I have 2 deployment servers on different vlans (different functions) and keep getting the alerts.
Sure an easy way is to disable the alert but it's a good alert to keep and would not want to disable it
