Lower bandwidth behind a MX67
NiklasW
Our ISP provides us a fiber 500/500 connection.
When I connect my laptop directly to the ISP's Router I get the full 500Mbit/s Down and Up.
When connected to the MX via 2 switches (MX (Copper)<-> MS120-24 (Fiber)<-> MS120-24) I get around 180-250Mbit/s Down and ~300Mbit/s Up instead of the full 500/500 - or at least 400Mbit/s which seems to be the max. for the MX67.
In the traffic shaping rules, I have set the WAN 1 & 2 speed to each 700Mbps.
Primary Uplink is the ISPs Router.
There is no bandwidth limit enabled.
The network uses no VPN.
I also tried disabling "Intrusion detection and prevention" aswell as "AMP".
Both had no impact on performance.
Currently running 18.210 Firmware.
Speedtest.net used for the tests.
Any ideas?
8 Replies 8
CptnCrnch
Upgrade to the latest 18.2 release and also check if there is some bandwidth limitation configured.
NiklasW
Alright, will be trying that later 😊
But as mentioned before - I have no limitations configured.
If you have security features enabled, Throughput will be reduced to a maximum of 400 Mbps.
D_Tak
If you have the ability and can plug directly into the MX do you see the same behavior? When doing this if you can remove all other LAN connections and if you have any default routing over a VPN please disable it for the testing. If the issue persists I would recommend opening a support case to have a Meraki Engineer look into the behavior.
NiklasW
Oh - by that test I found another bottleneck in the system - the integrated USB-C docks in our monitors.... 🤣
Jumped to 330Mbit/s. But not yet the full 400 which should be available.
The network I'm testing from is not a VPN network.
Same problem for me.  My monitor's integrated dock has a Gigabit port - but I can only get around 100Mb/s of throughput out of it (it varies up and down).  My WiFi connection is faster than my wired connection!
Whatever method you used for testing the "raw" ISP connection - use the same method to test while plugged directly into the MX.
If the performance is still not as expected - try giving the MX a reboot.  I have had the performance drop after doing lots of changes and a reboot usually sorts it.
Also check that the MX WAN port is reporting that it is connected to the ISP device at Gigabit full duplex (or whatever your ISP device needs).
