Local breakout from autovpn
DarrenOC
Taken from my LinkedIn feed from Gary Daly
[๐Œ๐— ๐”๐ฉ๐๐š๐ญ๐ž] ๐‹๐จ๐œ๐š๐ฅ ๐ˆ๐ง๐ญ๐ž๐ซ๐ง๐ž๐ญ ๐๐ซ๐ž๐š๐ค๐จ๐ฎ๐ญ (๐ˆ๐ ๐๐š๐ฌ๐ž๐) ๐Ž๐ฎ๐ญ ๐๐จ๐ฐ
One of the most popular ask from our customers is to locally breakout certain destination traffic.
We are pleased to announce that Local Internet Breakout for Meraki AutoVPN is officially released for all of our customers.
โ€ƒ
Johann
what version firmware does the device need to be on to see this change?
Aaron_Wilson
Has anyone tested this? It's not working for me.
I have a spoke site with the default route box checked, so all traffic goes back to the main head-end. I also have a 0.0.0.0/0 route advertised from the hub to the spoke sites.
I added ANY 1.1.1.1/32. If I try to ping from the spoke site Meraki (vlan, default, or internet) it does not work. Doing a trace from a device connected to the Meraki shows it's still following default route.
Do we know if routes advertised from the main hub have a higher priority than the VPN exclusion?
Now, if I use trace route on the Meraki this uses ONLY the WAN interface rule and bypasses all settings/rules/routes. Works just fine, but this is expected.
Aaron_Wilson
An update, if anyone cares.
Support is saying the VPN exclusion is meant to override the default route checkbox, but not routes learned via VPN. Which in my mind is pointless.
If a certain route is learned from a hub, but you need to exclude that route at a branch so it goes via the NAT interface, that is what the option should (also) allow.
jlkeys
We have been trying to get this feature to work with a Z1 (running 15.35 firmware) and have not had any success.  We have followed this document (https://documentation.meraki.com/MX/Site-to-site_VPN/VPN_Full-Tunnel_Exclusion_(IP%2F%2FURL_Based_Lo...) to split out ipchicken.com, but it does not appear to exclude the traffic.  We are not advertising a conflicting default route either.
