Load balancing question
trunolimit
How do I utilize load balancing on dual WAN while making sure one trype of traffic always uses a specified WAN?
RomanMD
Depending on what you consider  "a type of traffic" you can use Flow preferences and SD-WAN Policies.
Should be enough to
2 Replies 2
RomanMD
Should be enough to
SandroZ
Meraki Employee All-Star
Hi @trunolimit
as @RomanMD said the available option for traffic flows can be configured in Security & SD-WAN > (configure) SD-WAN & traffic shaping
Uplink selection > flow preference - L3/L4 filters
or
SD-WAN Policies > VPN traffic - for SD-WAN traffic, L3/L4 - L7 filters
Both configuration are a 'preference', if the specified uplink is down the MX will use the other uplink (if available)
Cheers
Sandro
