I have MX67W
And created 2 SSID's one for the staff and one for Guest
Can i limit the bandwidth for the Guest SSID?
If have MR AP's then its easy and the config is on the SSID setup.
But as i am using the bult-in MX67W i cant find that option on the SSID setting!
Tried to check the SD-WAN and QoS section by creating new policy and add my local Guest IP range and set the bandwidth but i was not sure if its the right way to do it as the limit bandwidth was max 5Mbps but i need to give them more like 50Mbps.
Any suggestions ?
