LDAPS through Meraki
Looker44
We cannot LDAPS through our mx250. I have port 636 open to my specific IP (also tried any). I can internally ldap (389) and ldaps (636) to server A. when i open 389, I can ldap (389) from external to internal, but ldaps(636) is an immediate fail.
is there a filter i can set on meraki to monitor port 636 from ip x.x.x.x? or is there a second step i need to do to complete ldaps to internal server.
I am using MS ldp.exe to test connections
6 Replies 6
You can perform a packet capture.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Packet_Capture_Overvi...
#1 issue when investigating these is Windows Firewall.  Try turning it off and testing again.
Otherwise as @alemabrahao says, perform a packet capture.
turning off Windows Firewall did not help
Looker44
thanks, ran a packet capture, but i cant read Klingon...
Looker44
PCAP shows that port forwarding is working but for whatever reason the LAN device (windows server)  is attempting to close the TCP session after successful TCP 3-way handshake and subsequent TLS Client and Server Hellos.
Try disabling  the Windows firewall.
I don't know if it makes sense, but you can try this configuration.
