Issues with Cloud Application Slowness.
MohanYadav
I am facing issues with Cloud hosted application accessibility issues via Internet.
How I Can resolve the connectivity issues. if I don't have control of their Cloud infra.
Kindly advise only case.
5 Replies 5
MohanYadav
Or else, In My Organization if, Site X having good high internet connection. so, if I make full Tunnel connectivity toward my X high internet site, then it will be helpful for cloud application for not?
Are you facing the same issue on the other sites? Is it possible test it with a site to site VPN tunnel?
MohanYadav
Most of the having issues while access cloud infra hosted application, but not have issues on Site.
So, according to you suggested, let's try to add few onsite with full Tunnel mode.
MohanYadav
In My Organization if, Site X having good high internet connection. and if I make full Tunnel connectivity toward my X site which have high internet connection, then it will be helpful for cloud application for not?
I didn't understand your question very well, but yes if you have a link with a good connection and especially if it is a dedicated link that the ISP guarantees the functioning of that link. But keep in mind that it's a two-way street, so where your application is hosted also needs to ensure good link quality.
