Is there a best practice SD-WAN Config for Custom Performance Classes
rhamersley
Is there a best practice SD-WAN Config for Custom Performance Classes for Meraki.
Is there a standard for Maximum Latency (ms)?
Is there a standard for Maximum Jitter (ms)?
Is there a standard for Maximum Loss (ms)?
Also...
Is there best practice for VPN traffic settings for Meraki?
SD-WAN Policies
SD-WAN policies can be configured to control and modify the flows for specific VPN traffic. With multiple WAN uplinks, the MX will proactively build multiple tunnels with each available WAN interface.  In the case where there are redundant WAN connections on the security appliance, traffic flows based on the type of traffic traversing the VPN connections can also be configured to allow for best performance. Custom policies set to desired preferences can be set to ensure traffic flows take the appropriate path based on your environment.  If a WAN connection that normally handles traffic such as file transfers begins to have performance issues, the Cisco Meraki MX can dynamically change the VPN connection to an alternative WAN uplink. This is done with custom policies or predetermined policies on the dashboard. It is encouraged to configure said policies in your deployment to best fit the needs based on the nature of the traffic and the capabilities of the WAN connections available on the MX
If you do have questions about what policies are best for your deployment, you can always reach out to either a Meraki Sales Engineer or your Meraki partner for a consultation on what best fits your needs.
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
Not really.  You need to determine what those metrics are based on your own deployment.
For example, someone on a fibre connection might have much higher metrics than someone on a cellular or satellite connection.
Also note than you don't need all values, here are a couple we use on dedicated fibre links:
