Is it possible to create a Split DNS in Meraki?
Jahir_xmartek
I need to crearte "Split DNS", “NAT Loopback” o “Hairpin NAT” in a Router Meraki. Is it possible?
I didn't find any guide about it.
Thanks!
KH
Hey @Jahir_xmartek
The MX does support hairpin routing:
Documented here:
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX#...
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
KH
Hey @Jahir_xmartek
Documented here:
Jahir_xmartek
Thanks!
GIdenJoe
Hairpin NAT works by default.  Just reach your own pub IP with the destination port you are forwarding and the MX will hairpin it back.  Be mindful however that if your MX is behind NAT itself (double NAT) the upstream device is in that case the one that needs to hairpin.
