Ipv6 headeach
Obel
Ipv6 headeach
Hi Team
We are using Meraki IPsec config with P2TP vpn connection on windows workstation.
I have also Azure Conditional access setup allowing access only from meraki external WAN Ipv4
Since month I am experiencing problem with users who`s ISP provide routable IPv6.
They connect to VPN without the problem but then some other services like MS Teams are using IPv6 provided by ISP and they are outside the tunnel.
I have checked IPv4 and IPv6 VPN tunnel settings on all workstations and they are not on split tunnel.  Is there any way I can force that IPv6 to go true the tunnel?
2 Replies 2
I suggest you open a support case.
I don't think Microsoft intends to update their client to handle IPv6.
You'll need to look at using Cisco AnyConnect.  I would use SAML authentication against AzureAD in your case.
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance/AnyConnect_Azure_AD_SA...
BUT
My first thought is - when you are pursuing a zero-trust architecture - why are you basing conditional access on an IP address?  Why aren't you simply checking that the computer accessing the service is a trusted, compliant computer?  I think if you resolve this issue - your entire problem will dissappear.
