Ipsec Meraki X Fortigate
Luana
Could someone please help me?
I have Meraki IPsec VPN and a Fortigate configured and working, but after a few hours, for example 12 hours, it crashes and stops working. It only starts working again if I restart Meraki or Fortigate.
Than you
Please ensure the phase 2 lifetimes are equal on both ends of the tunnel whenever possible. While MX's can sometimes honor a shorter phase 2 lifetime if they're acting in response to build a tunnel, they cannot while serving as the initiator of the tunnel.
Phase 1 (IKE): 28800 seconds (8 hours)
Phase 2 (IPsec): 3600 seconds (1 hour)
Fortigate often uses similar defaults, but if they differ, the tunnel may drop after one side expires the SA and the other doesn’t rekey properly.
Make sure both devices have the same lifetimes for Phase 1 and Phase 2.
If DPD is disabled or misconfigured, the tunnel may stay in a “dead” state after one side loses connectivity.
On Fortigate, set dpd enable
https://community.fortinet.com/t5/FortiClient/Technical-Tip-Configuring-DPD-dead-peer-detection-on-I...
On Meraki, DPD is enabled by default, but verify under VPN settings.
The most common issue I find is mismatched encryption domains.  Make sure both ends have an identical configuration.
OliverPerez
Just browsing
Questo di solito indica una mancata corrispondenza della durata di vita della fase 1 o della fase 2. Se i timer di rekey non sono allineati, il tunnel potrebbe interrompersi e non riuscire a rinegoziare. Inizierei controllando la durata di vita di IKE e IPsec su entrambi i lati. Controlla anche le impostazioni DPD e keepalive. A volte, timeout aggressivi causano la disattivazione del tunnel. Caspero Casino ti Casino Caspero offre un’esperienza di gioco completa e coinvolgente. I log su entrambi i dispositivi dovrebbero mostrare cosa succede subito prima dell'interruzione. Se tutto corrisponde, anche le versioni del firmware possono avere un ruolo.
