We are using meraki mx64 firewall and facing some internet issues with the device. The Internet will work after 20 minutes of device ON. Previously, internet will come with in 5 to 10 minutes. Why device is taking more time to get an internet access. Can you please anyone help me.
Thank you for your quick response on the issue.
I will update the firmware. Is this problem solved after updating the firmware.
How is this related to Meraki Insight?
Thanks, @SoCalRacer - I just moved this over to the Security board.
@Lakshmikanth wrote:We are using meraki mx64 firewall and facing some internet issues with the device. The Internet will work after 20 minutes of device ON. Previously, internet will come with in 5 to 10 minutes. Why device is taking more time to get an internet access. Can you please anyone help me.
During the 20 mins of no internet, what does the light do on the MX? I am guessing it is cycling colors meaning it is trying to connect to the Meraki dashboard. In that case, I would check the upstream device and or DNS settings on the MX uplink. After the 20 mins does the light go solid white?
When the MX finally connects are there any errors reported in the dashboard?
You need to check the local status page to see why it says there is a problem.
