Internet Breakout using DNS entries
Rafaelcabrera
We have a number of URLs included on internet breakouts in our MX devices.
The ones which are mostly ASW hosted services, the DNS URLs generally resolve to a CNAME and then to an IP address.
The IP addresses also appears to change dynamically from time to time.
Apparetnly the MX is not able to refresh its DNS cache in order to breakout the new IP for that particular domain, therefore the traffic is sent throught the VPN.
We have seen multiple instances where a URL domain is included in the breakout, but it is going through the SDWAN. We want this domains excluded from the VPN.
Does anyone have similar issue? Was there any resolution?
Kevin_R
Hello Rafaelcabera,
The way the DNS VPN exclusion rules operate is that the MX must see an unencrypted DNS response (using UDP port 53) back to a client device. The response does not necessarily need to be a particular client, seeing a DNS response to any client is fine. The MX will then add this IP/hostname mapping to its cache for as long as the TTL specified in the DNS response is. Once that expires the MX would need to see a new DNS response for the hostname, which if the IP changes, the MX should record that new IP and breakout the traffic appropriately. We have this information and caveats documented here: https://documentation.meraki.com/MX/Site-to-site_VPN/VPN_Full-Tunnel_Exclusion_(Application_and_IP%2...
This being said, Meraki support can check logging on the MX to make sure that mapping are correct along with looking into packet captures to see what the returned TTL in DNS query responses are. If you have not done so already, I would encourage you to open a support case so that support can look into logging and packet captures while the issue is happening with you.
Try blocking these two in content filtering (especially DoH and DoT).  This should allow the MX to see DNS and will probably resolve the problem.
MrFun7177
Did anyone ever find a solution to this? We have the same issue. Meraki said it was due to the TTL setting for the DNS domain. Most AWS DNS resolvers like Route53 has a TTL of 60 seconds. What I noticed was the local breakout would work for 50-60 seconds then revert to going across the tunnel instead of the local internet.
