Could you help me understand why I can't have internal communication between my VLANS, I have an mx64.
The situation is as follows, I have a desktop directly connected to the meraki that is on vlan 1 and has the ip 192.168.1.2 if on that desktop I use a VM that is on the same network (192.168.1.0/24) I can have normal communication.
However, if I put this VM on the VLAN 30 LABS network (192.168.30.0/24) I cannot have any type of communication, not even with the gateway (MX IP 192.168.30.1). However, from the desktop (ip 192.168.1.2) I can ping the gateway, but no other ip from the VLAN 30 range.
Below is how the VLANs are configured:
Meraki is currently with Client tracking in IP Address mode, even in Mac Address mode, the communication does not work:
There are no firewall rules or group policies blocking communication:
Group policies
ARP VLAN 30:
Tests vlan 30 not working
Test vlan 1 working
