I followed the documentation on Meraki in order to integrate MX with my Local Active Directory. I created an SSL certificate and did an ldp test which is successful whenever i use port 636 with SSL (checked/enabled).
I was able to add AD under the Security & SD Wan where the connection was successful and when I refresh LDAP groups appear (as created on my AD i.e. Restricted Access Group, INternet Medium & internet full).
However I have 2 issues:
1- Clients within their Groups (assigned to in AD) aren't applicable to any Group Policy from Meraki MX side
2- APs (when trying to enable Splash page) fail to connect (tried LDAP and ACtive Directory) it gives an error 249 (even though i am using the same username and password in Step 1- mentioned above)
check below screenshots :
