Inspection SSL in SDWAN Meraki + certificates management
kima25
I need the documentation regarding the support of SSL inspection in the Meraki SDWAN solution.
Thank you for your help.
Best Regards.
Brash
SSL inspection is not an available feature in the Meraki MX platform.
It was in beta testing at one stage but the performance impact was too great.
Nowadays for SSL inspection, the MX is positioned as a service edge to Umbrella where this can be performed.
KarstenI
As mentioned, not natively. And I also like the Umbrella solution mentioned by @Brash. But if you are looking for SSL decryption for both out- and incoming traffic, an inline IPS device between your MX and the next switch could also do the job,
You should head the warnings of @Brash and @KarstenI .
If you still want to go ahead, I believe you can open a case with support and request access to the feature and documentation.
AlexP
Just to give fair warning, in its current form,  it's a *very* limited support feature, and it's far from being something Meraki Support can recommend using.
