Implementing Group Policy to Integrated Active Directory
I'm new to the integration of AD and Meraki. Lucky, I was able to add my domain to meraki but I'm not able to apply my group policy to LDAP groups. I doubled check it by looking at the Network-wide>Clients. I tried to force my policy to the specific client to see if I configured the correct group policy and it worked.
I'm not sure if i've missed something on my AD but it shows "check" status in meraki.
I'm using MX84.
Thank you in advance!
7 REPLIES 7
Re: Implementing Group Policy to Integrated Active Directory
Hi @guzgerardo
I understand if AD Integration is successful with Dashboard. We can MAP the AD Groups with Respective Meraki Group Policy and this shall work.
Kindly refer the following image for more information.
Regards
Ajit
ajitsnw@gmail.com
Also note that the client needs to be using the MX for its default gateway for this to work.
Thanks for the response. That's the same setup I've config.
yes i've made the MX as default gateway.
Hi @guzgerardo
Is it possible for you to connect a PC directly to MX and Test?
Regards
Ajit
ajitsnw@gmail.com
Yes it's possible. Will have it test and revert soonest.
It is now working! Also tested it in MX ports. Knowing that I created incorrect switchport where the meraki was connected to the switch.
Additional question: what is the right way in activating Blocked/whitelisted url patterns? Should it be Append or Override?
