Hi @ITGOOKULAMKMK
Thanks for letting me know. So if the call connects and you get silence. Most likely the  RTP streams (it carries the audio) are being blocked or dropped.
So, check for things like (1:1 NAT, port forwarding, etc) on the Firewall. Also, have your team check the logs on the PBX/Platform for any NAT/Port issues.
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
