IPS/IDS Whitelisting
Lorenzo1
Hi everyone.
I've followed numerous threads on the subject , but I just wanted to check I've understood the replies correctly.
If I have  a cloud based threat & vulnerability scanning solution, it's not possible to white list the IP to allow Port scanning device subnets on the LAN side of an MX?
Ryan_Miles
Meraki Employee All-Star
If you have a supported MX model and run 18.2 you could look into using Trusted Traffic Exclusions https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Trusted_Traffic_Exclusio...
Ryan_Miles
RaphaelL
Yes (maybe?) with MX18.200+ and Trusted IP Addresses/Subnets
but.... I wouldn't run that version in production , seems super buggy. Your mileage may vary.
Wifikohai
Does anyone know if I add an Ip addres on Trustestes/network traffic. Traffic on any direction (from and to this host/network) won't be analyzed by the IPS?
