IP scope reserved for internal use
rhbirkelund
Today, while modifying a completely different VLAN this error showed up for a dummy vlan of mine:
I was not able to continue, untill I changed the IP scope of this dummy vlan.
Since when has this been a thing?
6 Replies 6
CptnCrnch
I guess that‘s a thing since RFC5737 (perhaps even since RFC1166) came out which declared 192.0.2.0/24 as reserved IP space:
https://tools.ietf.org/html/rfc5737
These blocks are not for local use, and the filters may be used in
   both local and public contexts.
rhbirkelund
The block is reserved for testing, I should still be able to configure it on an interface, that is not being used for traffic.
CptnCrnch
Strcitly speaking, it's reserved for documentation (see the RFC). 😉
One could argue if Meraki is simply following standards / RFCs or if you should be able to use it (and violate the RFC). On the other hand I don't think that the forums will help you further with this question.
rhbirkelund
Well, it's Cisco best practice to use 192.0.2.1 as virtual ip for web authentication.
So one could argue, that it should be allowed. 😉
No, I don't think that is the case.  They merely use it in their documentation - you know - the block reserved for documentation.
CptnCrnch
I hear ya...Cisco WLC != Cisco Meraki AP though. 😉
Guess we'll see many other interesting facts if the discussion continues, but as already written: I don't think this will bring you further with that request to be allowed to use that. 😉
I don't know, possibly Meraki is really using this space (because it's reserved) for some kind of internal stuff. At least I'd be really curious to get some deeper insight into that. 🙂
