How to identify a device causing a PCI scan failure
floridanativ
We are failing an external vulnerability scan because of a Linux Kernel 2.6 CPE vulnerability.  The scan is reporting the issues over ports 22 and 30005.
The scan results do not have mac address or IP for the device because it is an external scan.  How can I figure out which device is causing the issue?
1 Reply 1
AnythingHosted
If this is an external scan then I assume you have port forwarding under your firewall settings for ports 22 and 30005? That should give you the IP address of the device.
