Hi All,
We recently purchased a MX84 and configured it simply as a firewall routing internet traffic out. Nothing coming in.
Now we have a need to connect a Cisco 800 device to our network. This will provide a secure VPN connection direct to our client. They have provided the device. They say it needs it's own public IP address. We have a new static IP from our ISP for it.
I'm confused how this will connect! Here's some explanation of our setup:
Our internet connection comes via a fibre connection, with a RJ45 connector going into Port 1(Internet) or the MX84.
The WAN/Public address on the MX84 is set to xx.xx.xx.106. The gateway is set to xx.xx.xx.105. (105 being the fibre router)
There is no VLAN setup, but a single LAN network covering the remaining ports on the MX84
I now need to add the Cisco 800 to the mix. The WAN port on the 800 to have ip xx.xx.xx.107. How do I connect this up to the MX84 given that all the other ports are LAN with a different IP network range (internal IPs).
I think I need to create a VLAN but am struggling to find documentation on how to do this for our scenario.
Any help much appreciated.
