How to block Thunder VPN traffic and service port in MX-100?
Naw2
Just browsing
Dear All,
I have configured Splash page for guest wireless with billing. Now, I'm facing some issue. My issue is end user can access internet without login to splash page.  I have configured Advanced splash settings >> Captive portal strength >> Block all access until sign-on is complete. But, they can bypass our splash page using Thunder VPN. So, I would like to know how to block Thunder VPN traffic and services port in MX-100.
Please help to find the solution for my issue.
Naw2
5 Replies 5
Brash
You can enable the "Proxy Avoidance and Anonymizers". content filter category
However it may be hit or miss for certain private VPN's.
Naw2
Just browsing
I can't find "Proxy Avoidance and Anonymizers" in my content filter category.
Please check the following;
Please help to find the best solution. Thanks for your help.
Naw2
Brash
You're right, the category changed and is now split out to "Personal VPN"
As it looks like @Naw2 already has that category blocked, I'd install it on a client and see what servers it connects to to get started.  You can then create a rule to block those.  From the reviews I've seen they don't have many IPs per country, so whilst it will be a little bit of effort, it won't be that bad.
Try capturing "port 53" as it starts up and connects.  Note all the DNS entries it talks to.  Create a firewall rule to block those DNS entries.
