How to auto blacklist IP after a blocked attempt
Imperio
I have a couple of meraki mx84 firewalls and lately I have had several attempts to attack one of our webservers.
These attempts have been blocked, but after an attempt is blocked, this IP should be blacklisted automatically.
Is it possible to do this configuration?
Thank You
Brash
There's no native function for the MX to do this, but you could make a script that reads syslog messages and upon seeing one for a given attempt, can perform API calls to create a rule blocking this IP.
With that said, I would look at using a 3rd party service such as cloudflare to perform web server protection.
Imperio
Thanks for the suggestion. Given this firewall limitation, the approach might actually be to read the log and block every IP that makes more than x attempts.
This is a complicated subject, people often think that the firewall is the only security mechanism.
I guess the first thing to ask yourself is, do you need all of your servers to be published on the internet?
Ever thought of restricting access to specific IPs or even specific countries?
Imperio
This is not the only defense mechanism. And regarding the exposed servers, it's just a webserver.
As for the zone restriction, it is already in place. But if in an authorized country there is an attack attempt, there will be endless queries because there is no automatic blocking.
I will try to develop something local as suggested.
Thanks for the suggestions!
