How to: Deploy Meraki dual redundant vMX100 in HA config in Amazon AWS
I've managed to crack a problem I have had many people ask me - how do you deploy dual vMXs into Amazon AWS in a redundant manner.
The short answer - using an Amazon AWS Lambda script to check the status of each vMX and dynamically update the Amazon AWS route tables.  So if one vMX goes down everything will fail over nicely to the other vMX.
I have had my first crack at documenting the process and requirements here:
http://www.ifm.net.nz/cookbooks/meraki-ha-vmx-amazon-aws.html
1 Reply 1
WadeAlsup
Very well written article/documentation, @PhilipDAth
It always feels nice when we overcome challenges and I'm sure this will help some folks.
Kudos!
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
