How to Block external IP's on MX100
gparach
I need to enter IP filtering on the MX100 to keep certain IP's from trying to login to our mail server accounts causing them to lockout constantly. I do not have the option to only allow designated static IP's access to the mail IMap server. I also get monthly excel updates of Malware IP's and Domains that need to get blocked from/to our firewall. What method(s) will allow this?
Tat0rt0t
Perhaps the layer 7 section under Firewall you can deny a specified IP range?
12 Replies 12
MijanurRahman
gparach
This method wont work for users that don't have static IP addresses. I don't want an ALLOW list, I want a DIS-ALLOW list.
Mr_IT_Guy
Why don't you make a reservation for these users. This way they will have a static IP.
gparach
Because they are Public IP cell phone users.
Have you got an advanced security licence?  If so, go:
Security Appliance/Threat Protection/
AMP Mode=Enabled
Intrusion detection and prevention mode=Prevention
Ruleset=Security
Secuity Appliance/Content Filtering
Add: Bot Nets, Illegal, Malware Sites, Proxy Avoidance and Anonymlisers
Do the above till will gain you substantial protection - using dynamic lists rather than something manually configured.
gparach
I have the advanced functionality and am using it, but, I get advanced lists of known bad entities that I want to make sure are getting blocked.
To only allow specific IPs to get to your IMAP service go:
Security Appliance/Firewall/Forwarding rules
Locate your IMAP forwarding rule.  Scroll across to the "Allowed remote IPs" columns.  Change "Any" to just the list of allowed remote IPs.  All others will be blocked.
Tat0rt0t
The layer 7 firewall blocks outbound requests, not inbound requests due to NATed ports.
gparach
I have been using this method but was not completely convinced it was working. I tried another test and it seems to work from what I can tell. The only problem is it is an inconvenient way to enter many entries.
Tat0rt0t
@gparach So your post got me thinking and I spoke with out exchange admin as well about it. It does seem that we have no way to block specific IP's on a NAT statement. You can blacklist IP's however via exchange according to out exchange admin, but he did warn, if it is a attacker, They will just attack from another IP. His recommendation to solve this issue was the change the users account username for authentication.
gparach
This isn't exchange email and changing the user account is temporary at best (until they discover it) and a huge inconvenience to re-distribute the users change out to all contacts. My upcoming email version has Two Factor Authentication that should alleviate this issue, however, there should still be something built into the Meraki firewall to add IP block lists to reject someone trying to probe you or break in.
