How do i setup MX device to use Radius authentication?
We have deployed ISE in our environment and we fully setup Radius authentication from MR53s. We also have MX for home VPN and would like to setup radius authentication but it has different options then MR53s. Is there a different way to setup radius authentication on MX devices? Please provide a step-by-step document if there is available any.
2 REPLIES 2
Re: How do i setup MX device to use Radius authentication?
Hi @JaiminPatel ,
It's fairly straigh forward to configure for client VPN. You can find the settings under Security & SD-WAN > Client VPN.
Change the dropdown to RADIUS for authentication, and enter your server info.
Hi @JaiminPatel ,
Please find this link of our KB regarding dashboard side configuration for Radius authentication of Client VPN for your reference.
Hope you can configure your dashboard successfully through steps on this documentation!
