How can we use the Meraki client VPN and have MFA? How do we log user access?
Gleep52
I'm curious where I can find logs showing who has connected, when, and for how long - as well as how to enable MFA since Meraki is external facing.  Any one have info about this?
2 REPLIES 2
Brash
Enabling MFA for a user is done in the dashboard by clicking your account name (top right) and going to profile.
To enforce MFA for the organization, go to Organization -> Settings.
As for logging, all event logging for a given network is under Network-Wide -> Event Log.
You can then use filters there to narrow down what you're looking for.
If you have a specific client in mind, you can also select the client from Network-Wide -> clients and click "event log" or "timeline".
Edit: It just occurred to me you we looking specifically at client VPN.
Meraki client VPN doesn't natively support MFA but can incorporate 3rd party solutions
Two-Factor Authentication - Cisco Meraki
The above info about logging is still applicable for VPN connections, you would just filter to event type.
Do you have Active Directory?
If so, I recommend getting Cisco Duo for the MFA.
https://duo.com/docs/meraki-radius
Active Directory logs connections in the Security event log.
