All community
Knowledge base
Users
Show
only
Search instead for
Community Platform Help
Contact Community Team
Meraki Documentation
Meraki DevNet Developer Hub
Meraki System Status
All Technical Forums
SASE / Secure Connect
Cellular Gateways
Security & SD-WAN
Cloud Security & SD-WAN (vMX)
Switching
Wireless
Mobile Device Management
Smart Cameras
Sensors
Dashboard & Administration
Full-Stack & Network-Wide
Assurance
Cloud Monitoring & Management
Meraki Go
Developers & APIs
New Meraki Users
Tópicos em Português
Temas en Español
Meraki Demo
Documentation Feedback
Off the Stack (General Meraki discussions)
All groups
API Early Access Group
News & Announcements
Community Announcements
Feature Announcements
Firmware Upgrades Feed
Learning Spotlight
Marketplace Announcements
Meraki Unboxed Podcast
Community Tips & Tricks
Community Member Intros
Community All-Stars
Archived
Archived
This Content was Archived
Try searching for related content
// LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#pageInformation","feedbackSelector":".InfoMessage"}); LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox","feedbackSelector":".InfoMessage"}); ;(function($) { function makeid() { var text = ""; var possible = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789"; for (var i = 0; i < 5; i++) text += possible.charAt(Math.floor(Math.random() * possible.length)); return text; } $(document).ready(function () { $('body').on({ mouseenter: function(evt) { if ($(this).parents('.lia-component-users-widget-menu').length > 0) { return; } if ($(this).hasClass("disable-hovercard")) { return; } if ($(this).parents('.lia-component-common-widget-slide-out-user-menu').length > 0) { return; } evt.preventDefault(); evt.stopPropagation(); $('.hc-user-profile').removeClass('hc-animate-in hc-is-shown'); if ($('.hc-user-profile', this).length > 0) { $('.hc-user-profile', this).addClass('hc-animate-in hc-is-shown'); return; } var unqId = makeid(); var userId = $(this).attr('href').substring($(this).attr('href').lastIndexOf("/")+1, $(this).attr('href').length); var divContainer = $('
'); $(this).append(divContainer); $(divContainer).addClass('hc-animate-in hc-is-shown'); $.ajax({ url: '/plugins/custom/cisco/meraki/profile-card?tid=-2775051897031671627', type: 'post', dataType: 'html', data: {"userId": userId, "unqId": unqId}, beforeSend: function() {}, success: function(data) { $('.info-container', divContainer).append(data); }, error: function() { console.log('your error message should go here.'); $('.info-container', divContainer).append('
'); }, complete: function() { $('.spinner', divContainer).remove(); } }); }, mouseleave: function() { $('.hc-user-profile').removeClass('hc-animate-in hc-is-shown'); } }, 'a.lia-link-navigation.lia-page-link.lia-user-name-link,.UserAvatar.lia-link-navigation'); }) })(LITHIUM.jQuery); ;(function($) { $(document).ready(function() { var search_submit_span = $(".lia-search-input-field > .lia-button-wrapper.lia-button-wrapper-secondary.lia-button-wrapper-searchForm-action"); var search_autocomplete = $(".lia-search-input-field > input.lia-autocomplete-input")[0]; search_submit_span.insertAfter(search_autocomplete); }); })(LITHIUM.jQuery); LITHIUM.PartialRenderProxy({"limuirsComponentRenderedEvent":"LITHIUM:limuirsComponentRendered","relayEvent":"LITHIUM:partialRenderProxyRelay","listenerEvent":"LITHIUM:partialRenderProxy"}); LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:partialRenderProxyRelay","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":document,"action":"partialRenderProxyRelay","feedbackSelector":false,"url":"https://community.meraki.com/t5/contentarchivals/contentarchivedpage.liabase.basebody.partialrenderproxy:partialrenderproxyrelay","ajaxErrorEventName":"LITHIUM:ajaxError","token":"GCcSV40tkP1zV8gtvrM5NPkxTwe-MYMH0ar7ia0ywJQ."}); LITHIUM.Auth.API_URL = "/t5/util/authcheckpage"; LITHIUM.Auth.LOGIN_URL_TMPL = "/plugins/common/feature/saml/doauth/post?referer=https%3A%2F%2FREPLACE_TEXT"; LITHIUM.Auth.KEEP_ALIVE_URL = "/t5/status/blankpage?keepalive"; LITHIUM.Auth.KEEP_ALIVE_TIME = 300000; LITHIUM.Auth.CHECK_SESSION_TOKEN = 'mKp68iO_S9DA0t65HclyM_XoOSX225BsG0rh0WxYcQs.'; LITHIUM.AjaxSupport.useTickets = false; LITHIUM.Loader.runJsAttached(); // -->
