- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Helper IP
There are several instences where devices need to find each other across subnets. Cisco IOS has a feature called helper IP that can facilitate this. Does meraki have anything simila
Basically I have a Sonos system on one subnet and I would like to give people on the guest network access to the sonos system. Sonos can't comunicate with anything outside it's broadcast domain.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
However, if your guest network is cut-off/isolated then you will need to do some whitelisting for devices on guest network to communicate with other VLANs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I need to forward all sorts of broadcasts. not just DHCP requests. Will white listing forwards broadcasts from the sonos?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I always thought IP helper was a general broadast forwarding protocol but its strickly for DHCP. Sonos just doesn't support control outside of its broadcast Domain. I was on the phone with a really awsome support guy who looked at the packet captures from my phone trying to connect to sonos. They are using a proprietary protocol that resembles UPnP and a combination of broadcast and multicast traffic.
Sonos is just the worng product for what this client wants to do.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you describe how you solved this with DHCP Options?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Unfortunately I never did. My understanding of IP helper was wrong. IP helper only facilitates DHCP across subnets.
unfortunately Sonos just doesn’t work across subnets.
what you can do is set up a guest SSID but use firewall rules to stop anyone from accessing any resource other than the Sonos.
