Having Issues With 2 MX450s
MoJoPBS
Hello!
Quick rundown:
We have 2 MX450 merakis, one for each of our ISPs. They were in VRRP, we had issues with VRRP and made them separate about 1 month ago. Topology looks like this:
ISPs -> Merakis -> Palos -> Internal Cores
In addition, a separate VLAN on the merakis Meraki -> Internal Cores
2-3 week ago, we experienced a complete internet outage. We confirmed our ISPs were good, narrowed it down to the MXs, one is on firmware 19.2.2, the other is on 18.211.6 (why? I don't have control of them lol..) Ever since, every Wednesday at 2Pm CST we experience the same outage for about 1 hour. I noticed the Meraki on 19.2.2 is "rebooting" all things connected to it state the interface went down, in addition in it's logs it reports the same including WAN ports but it doesn't say it rebooted lol... I'm very confused. As for WHY both merakis keep going down, I don't know. Any ideas? Advice?
When our outages occur the logs state they lost connection to our internal gateway. In addition the Meraki on 19.2.2 I noticed in the logs soon after everything is online it did a "intrusion detection rules update".
I've read we should disable IDS/IPS.
6 Replies 6
If both are configured for HA, it doesn't make sense for them to be on different versions.
If you don't have access to their management, it would be a good idea to talk to someone who does to evaluate it.
I also suggest opening a support case with Meraki.
MoJoPBS
Both are now independent, I agree the firmware needs to be the same. We did create a support case and they want us to capture packets during the outage. Appreciate it!
RWelch
If it were me, I'd double check the ports (paths) are run correctly to verify something isn't causing the reboots due to a possible mis-configuration.
I would suggest opening a support case after verifying the ports (paths) to ask if support can see what's going on from the backend, perhaps that will give you a glimpse or insight.
And as @alemabrahao mentioned, it would be best to have both MX devices on the same firmware (if one gets updated the other does as well).
It might be best if you establish the practice that both MX appliances get updated/upgraded at the same time with whoever has access/control to firmware changes, perhaps they are unaware of the implications or connotations when HA devices aren't running the same firmware.
MoJoPBS
Yes, we're going to be down-grading the firmware so they're both the same. Thanks!
You must be doing some kind of route tracking on the Palo's.  Are they reporting they are up/down, and is that test correct?
RalphDiaz
Sounds like a firmware and feature interaction issue more than a pure ISP or hardware failure.
Running mismatched firmware on MXs in similar roles can absolutely cause weird, time-based behavior.
The Wednesday 2 PM pattern is the biggest clue.
That lines up suspiciously well with scheduled maintenance tasks, like IDS/IPS or signature updates.
The “interface went down” without a reboot usually points to the dataplane restarting, not the whole box.
That would drop WAN and LAN briefly and look like a reboot to downstream devices.
I’d start by disabling IDS/IPS on both MXs as a test.
Also try to get them on the same firmware train if possible.
At King Johnnie VIP, users https://kingjohnnie-vip.bet experience online gaming within a polished VIP-style setting.
