Guest Wifi with "internal" captive portal
suneq
I am asked to design a Guest Wifi architecture for spokes with some basic requirements:
- Guest Wifi user should have access to Internet only
- A single Guest Wifi subnet should be used for all 600+ sites
However, the splash page should be stored in an internal server which is located in the Data Center / hub. This splash page will not be reachable via Internet.
From my understanding, if the splash page is only reachable from AutoVPN tunnel, I guess that the Guest Wifi VLAN / subnet of each spoke should be advertise to the hub => so we cannot use single Guest Wifi subnet but we should have 1 subnet per spoke and things get more complicated.
Am I correct? Is there any way to meet the requirement? Thanks for your advice.
Ryan_Miles
Can the splash page be replicated in the native splash function of dashboard? That would greatly simplify your design, provide resiliency, and require no VPN tunnel.
Ryan
suneq
Hi @Ryan_Miles, the client has their captive portal Ucopia which is working well and therfore, they do not want to change anything.
Any solution for that? Thanks.
I don't think this is a good design.
If you want to write a captive portal integration take a look at the EXCAP guide (option 3).
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_captive_portal.pdf
Here is the developer guide:
https://developer.cisco.com/meraki/captive-portal-api/
Otherwise, if you want to pursue the layer 2 strategy, you'll need to deploy an MX in VPN concentrator mode wherever your portal server is.  Then configure the SSID to use tunnelling.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/SSID_Tunneling_and_Layer_3_Roamin...
Beambox
Regarding not making it accessible on the internet, I wonder if you could use some Cloudflare rules to handle this at the DNS level?
One unique aspect of the Meraki captive portal is that it passes in a selection of URL parameters with information such as the device MAC/IP.
You could filter based on this, concealing the splash page unless these URL params are present.
