I've never looked into the Zscaler app before, but am i correct when I say that basically all your outgoing traffic gets tunneled to Zscaler via the app?
If only access to the IPs you listed is needed for that, why don't you use the L3 firewall to block all outgoing access except to those IPs? Seems to me that using the URL blocking feature is not meant for that?
Probably stating the obvious here but test on non-production first 🤣
