Group Policy / AD Authentification
TimBisel
I am trying to apply Group Policy with Active Directory integration. I have Active directory setup and looks fine there, and I tested group policy with manually applying it to machines and it works there. But I can not get it to work when applied through AD integration. I verified that I am attaching it to correct group, but in the event log I do not see where AD authentication is being done. Does it matter that the machine if physically connected vs wifi? Can anyone give me next steps on where to look.
2 Replies 2
Are you sure you have auditing enabled in AD - and do you see the audit events appearing in the event viewer?
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Active_Directory_Integra...
TimBisel
I will double check thanks. Will report back.
