Glc-te on mx250
yusufbudi
Glc-te on mx250
Hello
Can we use the glc-te for the internet link in the mx250
Yusuf
MarcP
as it is copper cables which can be plugged in into the MX250, I would say yes.
hoempf
Officially it looks like it's not supported:
https://documentation.meraki.com/MS/Other_Topics/MS_Switch_SFP_and_SFP__Overview#What_if_I_need_to_s...
This is for a switch though, but I assume they won't test 3rd party SFPs on MXs neither.
But I suggest you try. We had great success with programmable SFPs from 3rd party vendors in Meraki devices. Cisco "classic" SFPs (like the one you mentioned) not so much. But this is only our experience, yours may vary.
CptnCrnch
Please have a look at https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf
MA-SFP-1GB-TX is listed for being supported on MX250 also.
We have been using a Cisco GLC-T module for the internet connection of an MX250 that is the one arm concentrator in our main datacenter for a country-wide SD-WAN for over a month with no issues.  Meraki will investigate any issues with unsupported modules, but if the module looks like it might be the cause they will ask for it to be replaced with a supported one before completing investigations.
