Full or partial site to site tunnel with non Meraki VPN
ID
I am trying to create a tunnel between a Meraki MX84 and a Cisco ASA 5510 which contains 3 different subnets, e.g a 10.0.0.0, 192.168.1.0 and 192.168.2.0.  The tunnel seems to come up fine but only the 10 network actually works.
Can anyone think of something i might have missed?  Or something thats weird in the way Meraki Deals with multiple subnet VPNs that i may have missed?
ID
I worked it out.  I had missed a NAT exemption rule on the ASA.
Thanks for the help.
6 Replies 6
nealgs
In the settings for the VPN on the MX84, under the section VPN settings/Local networks, are the 192.168.1.0 and 192.168.2.0 networks listed?
I've just setup something similar but to a ASA 5525 and only with 1 subnet.  I'd expect any other subnets to therefore appear under the above VPN settings/local networks section and give you the option to Use VPN or not.
rgds
Gary
ID
Thanks for the reply,
Sorry i should have said that the subnets are all at the ASA end.  The Meraki just has a single subnet.
nealgs
what does a tracert show from ASA side 192.168.x.0 to the MX84 side?
Is the ASA side set to route those subnets over vpn?
ID
nealgs
great stuff - thanks for letting us know the outcome 🙂
Gary
DangItCarl
Hey I am stuck trying to get a Z1 to talk to my 5508 The 5508 wants a static ip (I think) for the peer but the Z1 is on a home DSL with DHCP.
Any pointers?
