Firewall info - open ports for Meraki dashboard
Proxy
Hi all,
So today I noticed that the destination addresses listed under firewall info for my dashboard had changed, and this explains nicely why some devices have been having a hard time connecting to the dashboard.
My question is - for MX devices, what source address would they use management connections on TCP/7734, 7752 and UDP/7351, 9350-9351?  I can packet capture and see this traffic on the WAN interface, but not always the LAN interface (espcially the UDP traffic).  This might just be a coincidence because I am capturing at different times, or does the MX originate the UDP traffic from the WAN address (i.e. not one of the LAN subnets)?
Thanks in advance.
1 Reply 1
Yes from wan interface/ip.
If you see traffic on the mx lan to meraki subnet/ports its most Likely  a AP or Switch management ip.
