- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Enabling Load Balancing on live network
Hi all, I have 2 MG's connected to an MX unit and the site is currently live and working. i would now like to enable load balancing feature but I am unsure if this would cause any drops / outage for a brief time whilst the system reconverged. Would anyone know if this would be the case? Thanks for any advice.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Changes should be simultaneously, existing sessions should not be affected as the MX is a stateful device.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @Andrea_Hopkins,
As a general rule, it is normally recommended to make any dashboard configuration changes during downtime or in a maintenance window. If any unanticipated issues arise as a result of the change, it will not affect live production and can be reverted without significant impact. Additionally, if the changes are being made on a specific model device like the MX84, it is a known unresolved issue that a brief period of packet loss may occur when a configuration change is made on the appliance, as seen in the firmware change log below:
Best,
Feli
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Feli,
thank you very much for your advice. As you stated, this is to be carried out during a specified window, i was just curious that was all. I did not, however, know about that unresolved bug regarding the MX 84 so thank you for sharing.
kind regards,
Andrea
