Dynamic Protocol Status
networkninja_
iBGP alerting, peer status stays in "Connect" and not learning any routes. Has anybody experience this issue?
Are there any firewall rules or ACLs between the MX and the peer that could be affecting communication?
I also suggest you open a support case.
networkninja_
No there is no ACLs or rules setup, I am allowing the traffic, this were up and working two days ago and nothing has change, I do see logs for VPN tunnel connectivity change going from True to False every minute.
Yes let me open a support case
Anything in the Meraki event log?
What about the log on the other end?
Can you ping the remote peer from the MX?
I assume there is nothing doing NAT between the two peers.
