Hi guys,
Just wanted to give you an update on my issue.
I might have gotten very close to the issue.
I have figured out that it is an old script running on an old server 2003.
The script connects to an FTP ( Active ) Unsecured and uploads the files.
However, it does not work. Anyway, if I change it to passive mode. it works!
Going through the logs of the FTP transfer I find that it connects fine, and then times out. searching for this issue, it seems there is a bug in the specific software version of WinSCP they are running. that might cause this.
I will upgrade the software and try it out again.
best regards
Daniel
