Does Meraki MX series have auto-MDI/MDI-X function ?
Soichiro
Hello !
I'm network beginner and facing Meraki MX device implementation work will begin soon.
with regard to the function described as title, I would like to know does following MX products have auto-MDI/MDI-X function.
<Products>
MX67/MX85/MX105
I couldn't find MX series switch has but MS series.
Would it be possible for someone who knows this teach me ?
Thank you !
2 Replies 2
CptnCrnch
As far as I know, it is supported but not documented.
Brash
+1 I believe it's supported/implemented but not documented.
That being said, there's at least one instance in the community where a crossover cable was required between and MX WAN port and the ISP device - Solved: MX64 Internet port link drops at 100/full (okay on auto / auto) - The Meraki Community.
However, it seems likely that it was the ISP device that didn't support auto MDI.
