Disable 'Guest SSID' to be appear in client description
Syz-
Hi all,
I created a new SSID 'Guest@xxxx' on MR33. My question is how to disable every guest connected to this 'Guest@xxxx' appear in Network Wide>Monitor>Client.
Please help. Thank you very much.
7 Replies 7
Do you mean disconnect them?  Disconnecting WiFi clients configured for an SSID doesn't really work, as they'll just re-connect.
You could apply a group policy and simply block the user from everything.
https://documentation.meraki.com/MR/Group_Policies_and_Blacklisting/Blocking_and_Whitelisting_Client...
Thank you for your reply.
Actually I want all user connected to the network that I created to have inventory in dashboard except for guest. In what way I can achieve this ?
AjitKumar
Hi @Syz-
If I am understanding your requirement correctly.
Still... I think filtering the Display shall be one option.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
thank you very much sir.
AjitKumar
Hi @Syz-
I do not see an Automatic Method of disabling  to all clients to specific SSID. May be by device type you can apply Block Policy automatically.
One Idea could be filter the clients on the basis of SSID.
Select All Clients
Apply Block Policy
All these options are available in
Network Wide>Monitor>Clients
Just for information
Why do you want to block all the clients?
You may simply Hide or Disable the SSID too.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
A good and easy method for a small number of devices (or if there is no Active Directory) is to use WPA2-Enterprise mode and cloud hosted autentication.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Meraki_Cloud_Hosted_Authentication
