Deploying secure client modules with SM
Simone
I was wondering if there's a way to push ths installation of secure client module: Umbrella, NVM, VPN, Thousand Eyes, ZTA and also pushing the OrgInfo.json file for umbrella configuration.
Is there any documentation available?
Simone
1 Reply 1
CharlesLopez
Hi Simone, yes, you can automate deployment of the Secure Client modules (Umbrella, NVM, VPN, ThousandEyes, ZTA) along with the OrgInfo.json file. Typically this is done using the Secure Client pre-deployment packages combined with your endpoint management tool (like Intune, SCCM, or Jamf). You place OrgInfo.json in the Umbrella module directory during install or via a post-install script. Cisco provides step-by-step guidance in their Secure Client and Umbrella admin docs, especially around “customizing and distributing modules” and “Roaming Client deployment.”
