Deploying Meraki MX HA using VRRP
adten
Please does anyone have experience with deployment of HA for two MX 67 using VRRP.
We are planning to deploy HA for two MX 67 using VRRP and need some helpful hints for the implementation in such a way that Dual Active issue will be avoided.
Thank you
4 REPLIES 4
KarstenI
Re: Deploying Meraki MX HA using VRRP
Here is a guide to follow:
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
Why are you mentioning Dual Active issues? Did you have trouble before?
@adten the approved setup is to have two LAN ports on each device connected to two separate LAN switches.  We follow this with switch stacks where each MX has one LAN cable to the first stack member and a second LAN cable to a second stack member.  This has not caused us any issues (unless you reboot the whole stack) in over a year.  If you have separate non-stacked switches it is often safer to only connect one LAN cable from each MX to a LAN switch to avoid a layer 2 loop being formed and not being dealt with properly by the spanning tree protocol.
adten
Hi cmr,
Thanks for the response. But I need clarification on 4 points -
1. In the approved setup you referenced, is it only one LAN port on each Meraki MX device that should be connected to stacked switches
2. Is a virtual IP required for these two Meraki devices or only physical IPs will suffice
3. If physical IP addresses are required, how will the routing be done to ensure failover occurs in the event one of the devices fail
4. In a situation where you have only two WAN links, can they be connected one per Meraki device ?
Thank you
@adten in answer to your questions:
  1. Two LAN ports per MX for approved setup, however 1 works better if switches not stacked
  2. Virtual IP is for WAN side and for each ISP you need a minimum of two public IPs (one for each MX) and ideally 3 (the third for the virtual IP)
  3. Virtual IP above is used if configured, if you don't use virtual IP then it is not seamless but the physical ones are used.
  4. No, use a dumb L2 switch to split the WAN port from the ISP into multiple ones, one switch per ISP
