We use a Meraki MX67C with a DHCP service enabled.
We have a SCCM server to deploy images on the same subnet and this is working fine with PXE boot.
This SCCM server will be removed so the second one in another subnet sitting in another country will provide this instead. Can i set the Meraki to forward the PXE request to this server located in another subnet ?
Note, we can not use boot filename as we have several boot files.
Is the fields below the "ip-helper" part in this Meraki unit ?
If possible, what must i do to make it work ?
BR
Elefanten
