DC design questions
etalaveran
DC design questions
Hi
I have some design questions regarding MX on DC
I see that performance is about clients and VPN throughput. But there is any info about the maximum number of VPN tunnels?
If I have in a DC 2 MX :
  • The only way to configure both devices to  concentrate the remote sites is HA in WarmSpare?
  • Active/Active HA is possible with 2 MX?
  • If one HA pair fails, whats the the convergence time to the Warm Spare?
Is possible for a remote site to access The Dashboard using MPLS links via DC internet access?
 Regards
This guide lists the maximum number of VPN tunnels (page 2).
https://meraki.cisco.com/product-collateral/mx-sizing-guide/?file
Depends on the type of failure.  Usually 10s to 30s.
Check out this DC to DC failover guide.  It uses an active/active design.  It uses a pair of MX in each DC (4 in total), but in your case you might only use two.  Note that they MUST have a seperate and unique stub network each for this to work.  You also need to use dynamic routing.
https://documentation.meraki.com/MX/Deployment_Guides/Datacenter_Redundancy_(DC-DC_Failover)_Deploym...
BGP is the most popular routing protocol for this kind of design.
https://documentation.meraki.com/MX/Networks_and_Routing/BGP
2 Replies 2
ps. Because of the complexity that active/active adds - I would always go up a model if I was able to use warm spare instead.
Aaron Willette wrote a good active/active guide as well.
https://www.willette.works/active-active-meraki-sd-wan-headends/
